Couple of things geezer; When you're driving the car, are you smelling a sweet smell inside the cabin with the heater running and fan at medium speed? You can actually taste it through the cabin air... Also, have you noticed and strange "fogging" on the lower inside windshield? (smears when you attempt to wipe it off).
If you answered yes to any of those 2 questions,you may possibly have a heater core or/inside hose connection leak.
Do a stone cold test: making sure the car has set overnight (you want the engine to be stone cold), open the hood and open the antifreeze reservoir ....rock the car back and forth a few times while keeping your eye on the reservoir and see if you notice any air bubbles coming up to the surface ( after the dealership topped the antifreeze,it should have been bled to remove excess trapped air in the system).
Using a Marker, put a small check mark on the plastic reservoir where the antifreeze level is, close the reservoir lid...and go for a drive, make sure the system has come up to full temps before you return back to your garage....while out driving, cycle through the heat settings; feet area only,middle, and top (defrost), and run the fan on high while doing this....this will help remove ANY remaining air in the closed loop system.
Head back and park the car and leave over night again,(obviously, on level ground) the following day, pop your hood and take a close level look at where the antifreeze is sitting compared to the marker you put on the day before...if the anti freeze level has gone down anywhere between 1/8" to a 1/4" it might be a blown head gasket (highly doubt it). report findings to your dealership if that is the case for further investigation.
Hope this help you out.
