1 - 12 of 12 Posts
Wanted to share this recall notice that I got in the app yesterday. Called my service manager and he said that it’s not urgent, but should take care of it as soon as it’s convenient. He mentioned that the current program may overheat the catalytic converter, and the reprogram will fix it. They are adding an additional 12 months of transmission warranty from the date of reprogramming as a backup.
6059
i just looked and saw that. thanks for the heads up.
So I am curious. I don't have that recall for my car. Granted Lincoln won't touch my car with all the custom work I have done. My Vin is a 2017 2.0l. Maybe this is only for the 2.3. I better flash it myself then.
Correct, the SM told me it was told 2.3L engines, not sure if it's only AWD or not though.
Received recall letter. Has anyone done it? I would like to know how long it actually takes, letter stated 1/2 day and with the distance, 50 miles, and the Vid spike in that area I want to spend the least time as possible. I can change/adjust torque converter in my F150 in about 5 minutes.
I also got the letter. Met with the SM. He didn’t seem to know much about the fix, other than it is a software update. If they install the update, Lincoln will warranty just the torque converter for a year from the update date.
I told the SM that if they can’t tell me what the update will change, I’ll decline the update, as my 2015 C with 71k miles runs so good I don’t want to take a chance on them fixing what is not broke.
Discussion Starter #7
Did it a couple of weeks back. Took around 45 minutes before they took the car out to get it washed. All in all I was out of the dealership in about an hour with paperwork. I can't tell any difference in driving, although the problematic issue that the recall fixed may not be apparent unless you are doing long distance driving or towing.
Reactions: TxTom
Called the service tech and he said they take about an hour so no big deal. He suggested getting it done when I had vehicle serviced, kill two birds with one stone since it is about due.
I believe the current program may over heat the torque converter, not the catalytic converter..
Had the recall done, about an hour, had service done also. Anybody that had it done notice a difference in gas mileage? May just be the cold weather but our mileage is down, not going to panic until the weather gets warmer.
Had this done couple months ago to my 2.3 AWD. Haven't noticed and difference, also no change in the gas mileage which is not very good since it is used only around town driving. About 17-19 MPG depending. But straight freeway driving only at about 65 MPH is 26-27 MPG.
We avg around 24 but with the weather being so cold, double digit negatives, and no long trips and remote starting, longer warm-up times, that will zap mileage.
1 - 12 of 12 Posts
