Hi all
The admin key has never worked on my Lincoln the most irritating aspect of which is the stereo volume will not turn up above half level
I am in the U.K. and in the process of ordering a new admin key from the USA. Will the new key need programming, when it gets here bearing in mind Ford U.K. say because my car is an American import they can’t work on it so how can I get the new key programmed?
Any help very much appreciated
Tracey
Your new key will need programming. Actually the car is programmed to accept the new key. Most locksmiths should be able to do the programming. They are usually cheaper than the dealer. If you can't find a locksmith I have some other ideas.
Sanman
By me Ace Hardware redoes the keys and programming.
