The weatherstripping is loose/unattached. Any advice as to how to reattach? The plastic 'attachers' are still in the door but hard to figure out. This is on the door itself, not the doorframe.
Thanks.. Slow and a 'thin' needle nose did the trick. Was not able to get the little purple clip out but just stretched the hole over that one so it's back too.So those clips Will come out but you have to be kind of slow when you pull them out there they have two fingers that stick out in the same direction as the ears on the end of it if you can slide the clip as far as you can One Direction or the other and then take them needle nose plyers and twisted out, it’s really hard to verbalize how to do that I hope that makes sense
