Hello. I recently purchased a 2018 mkc reserve. It's the top trim you can get in Canada. I noticed that in order to run my day time running lamps which I would have called fog lights since my last vehicle was a truck. My question is their a way to run my day time running lamps and my headlamps at the same time at all times without having to turn light switch off of auto? When my nighttime lights come on my day time running lamps won't come on. Only way I've seen to turn on my day time running lamps is to manually turn the light switch to have lights in which is a problem because if I forgot their on and shut off the vehicle that would kill the battery. Is their a way to have your day time running lamps come at the same time as your headlights in the auto headlights setting on the dial? Ill attach a few images to give you an idea of what I mean.
