1 - 20 of 26 Posts
Discussion Starter · #1 · (Edited)
Hey guys I forgot I did this a year or so ago until I was chatting with @starzplacez and @PSUnexus . If you have access to forscan you can easily add tire pressure gauge to the instrument panel. If you have a low tire it will illuminate it in yellow as well. A word for the wise though, this information is only accurate if you retrain your tire after each tire rotation.
If you are unfamiliar with forscan there is an abundance of information online to train yourself.
First log into forscan and click on Configuration and programming
Then find IPC, not IPC (As build)
Then find tire pressure gauge and click on it.
Change Disabled to Enabled and click write
Cycle ignition on and off and congratuations you now have this.
Text Line Font Screenshot Software
Text Line Font Software Screenshot
Vehicle Car Speedometer Auto part Odometer
@Buckeye you just need to make a trip to Pennsylvania or Smoky mountains;)
Discussion Starter · #8 ·
I am in very a desolate area of the country right now. I will look into this when I get home this weekend. What is your car info and forscan version?
Discussion Starter · #10 ·
Try updating to 2.3.40, that is an old version that you have
Discussion Starter · #12 ·
OK, I can check online to and see if that’s the case on the newest version otherwise give me a few days and I will find the manual coding for it
Discussion Starter · #13 ·
Okay I found the problem you are having. Forscan has changed the name of the code from tire pressure gauge to TPMS menu. Try that and let me know if it works!!
Hi. I've completed the process above to add Tire Pressure Gauge to my 2015 MKC. It all appeared to work, Forscan connection, IPC Config, including changing the setting to "enabled", writing the block, and being prompted to turn off/on vehicle. BUT, I still don't have a gauge in the Driver Assist Menu. Any additional thoughts? I even tried the older version of Forscan 3.3 with "Tire Pressure Gauge" still in the IPC Config. Thanks
Discussion Starter · #15 ·
I don’t know, you sure appear to have followed it exactly like you needed to to make it work. One thing you could try to do would be a IPC reset, Now the option is all the way down at the very bottom of Driver assist, did you scroll all the way to the bottom until it cycles back to the top correct?
Thanks! Do you mean reset IPC in FORScan or is there a option for that on the dash? Interestingly, my DriverAssist menu on the dash only has “Rear Park Aid” and “Traction Control” in the list, so, nothing to really scroll down too, and choice to reset.
Thank you!!!!!
Discussion Starter · #17 ·
Yeah there is a module reset option in forscan. I can’t remember what tab it’s under right now but if you can’t find it I’ll check for it tonight when I get done with work. All it does is force the module to fully power down and power back up.
I have personally done this to my parents MKC also which is a 2015 so I know the software will accept the coding
Discussion Starter · #18 ·
@dstas any luck? Do you need anymore assistance
View attachment 6040 View attachment 6041 View attachment 6042
Can ask a stupid question, I’m new to all this and mom just bought a 2017 Mkc and she hates that she can not see the individual tire pressure. My question is what is the Forscan is it a hand held dio computer or is it built into the mkc hard wired computer. Any help would be greatly appreciated. Yours truly newbie 😎
Until now I didn't realize there wasn't a tire pressure gauge shown . . . my base trim Hyundai Tucson has this feature enabled (though no compass feature like the MKC has, a big oversight from Hyundai) That's an incredible oversight from Ford not to show that. My F-150 does. I'm too scared to use Forscan and mess something up (and don't own Forscan) but luckily I can see each tire's pressure using LincolnWay.
1 - 20 of 26 Posts
