I cannot figure out how to play the stereo with the engine off. I can’t find an Aux setting on the ignition button.
Is there a way to just run the radio for longer than 10 minutes? I am frequently in a position where I would like to listenYou can also turn the vehicle completely off after turning it on, the stereo should continue to run if your battery has adequate charge until you open your door or you leave it sit for approximately 10 minutes
to the radio without needing to push the start key every 10 minutes. Sometimes it seems it doesn't even run 10 minutes
before complaining about the battery. It's probably because many other circuits are activated.
I would just like an accessory position like it has on most cars.
Thanks. Maybe the reason there is the 10 minute max and subsequent warnings about the battery is because so many things seem to be enabled, windows, DVD, Nav, etc. Maybe I'll need to take a transistor radio with me.No not really, your best bet is just to turn the car on and turn it completely off and let the delayed circuit time out in 10 minutes. I'm right there with you I wish there was a way to do it but I've not found it
Brilliant! The radio stays on even with the door opening and closing. Perfect, thanksAfter the 10 minutes when the radio shuts off, I just press the radio power button and the radio comes on again. No need to press the Start button.
This also supplies power to the USB ports.Brilliant! The radio stays on even with the door opening and closing. Perfect, thanks
