1 - 2 of 2 Posts
Has anyone noticed your battery dying after a couple days.
It seems that when the car is locked using the door lock button the dash stays on and the push start is lit up.
Is this normal?
nope. it's draining your battery. you need a good tech to diagnose the part that is causing the drain. you could try pulling fuses and/or relays to help narrow it down but that may not help you identify the actual part.
1 - 2 of 2 Posts
