Ratio parts inside a transmission are all physical hard parts gears and the like which can't be changed by programming. Doubt it can be done without changing the entire transmission, if that's even an option with so many others things needing change i.e; wiring, ecm programming and who knows what else. Possibly by changing pinion gears, but being an all-wheel drive, just researching what would be needed - if parts were even available.Is there any reasonable (cost, time, and reliability wise) way to change the automatic transmission top end ratio to increase hi-way gas mileage?
