My 2015 Reserve has an occasional glitch that has showed up maybe 3 times in the last year while running A/C auto:
After restarting, despite what the settings are set to on the control, the drivers side will go to max heat and crank the fan all the way. The passenger side center vent and corner vent stay on commanded temp.
Tried cycling the Climate control ON/OFF with the power button. Nope. Also tried running to MAX COOL. Nope.
But when I pushed the heat in both zones as high as allowed, I found that as I backed down, the driver's side once again followed commands. Hard to noodle out whether this is a sensor, wiring, or software logic problem.
I don't think there is any point going to a dealer until it is permanently malfunctioning, but I will probably swing into the lot with my shirt off..........
Thought I would share.
