1 - 12 of 12 Posts
Discussion Starter · #1 · (Edited)
I've had my MKC for a little over a week. Build date is 1/29/2015, so it doesn't have the updated climate controlled seats. We had a fairly cool day (high 50s) last week and tried the heated seats. I thought they heated quickly enough and were warm enough on all 3 settings. I had a 2004 Lincoln LS a few years back. While the MKC's seats don't seem as warm as the LS, I thought the amount of warmth would be enough in cold weather. However, the cooling function of the MKC seats seems significantly less that the LS. I can hear the seat fan running, and there is definitely air moving through the seat and the backrest, but it doesn't seem very cool, maybe only a couple of degrees cooler than the ambient temperature. The seat seems maybe slightly cooler than the backrest. I don't detect any difference in the degree of cooling between the driver and passenger seats/backrests.
TSB 15-0027 cites an issue with heating, not cooling, although the same module controls both the heating and cooling functions.
  • For those of you who have cooled seats, is your experience similar to mine (that is, the seats provide more ventilation than actual cooling)? Is there a difference in amount of cooling in the seat compared to the backrest?
  • For those who have had the TSB performed, have you noticed any improvement in the cooling function?
For my MKC, very good improvement in the cooled seat performance...both speed for it to cool and the temp of the cooling. This is with the A/C on. And compared prior to the TSB. Mine was built in July.
Mine was built in April 2015. Is this after the TSB?
I am somewhat disappointed in the speed and temperature. It seems to take maybe about 5-10 minutes before I start "feeling" it. I've never had the feature before so I cannot compare it on what it should feel and perform.
I mostly just feel the air coming from the bottom seat. Little to none from the backrest.....probably something to add to the list when I have the replacement antenna installed.
So TSB helped both heating and cooling? Great, I need to get it done. Did you get any static from the dealing in requesting that it be done?
Tru Blu, thanks for the response. Sounds like yours works like mine, although your MKC should have the updated module. TSB 15-0027 applies to builds on or before 2/20/2015.
yes, I have same issue. Heating takes 15 minutes (pretty much more than most of my drives) and doesn't get a fraction of the temp of my husband's escape titanium. Cooling seats only feel marginally cool if I have the A/C cranking after 10 minutes like you said. I can hear the fan going and feel a little coolness from the bottom but not the back panel. I confirmed with dealer that bottoms and backs should heat and cool...
They are aware and are fixing it with new foam pads and heating elements in seats. Not exactly sure what they do for the cooling part... Dealer at first said software (?) even when it was being reported here that seat pads and elements need to be ordered. That's why I love this forum, you guys seem to know more!
A few have reported here I believe that they have had it fixed and its much better. Hopefully getting mine in for the fix in the next week or two..
I'm probably repeating myself here (I believe I mentioned this in an earlier post), but for the record my dealer refused to apply the TSB to my vehicle, despite my complaint about the heating. They took a temperature probe and found the seats heated to a temperature "within specification". Of course, this test does not address the quickness (or lack thereof) of getting to that temperature. I may try again with a revised complaint about the slowness in the seats getting cool (I'll try to emphasize the timing factor this time 'round).
No issue from the dealer. They have an excellent service tech now. First attempt before the TSB, with a recently fired tech, messed up the installation. The "foam pad" was reinstalled previously partially blocking the vent tube that funnels the A/C air to be distributed throughout the seat. Finally this excellent tech got the new parts and did the install. Works as good or better than my '12 SRX...which is long gone.
Discussion Starter · #10 · (Edited)
Interesting that they refused. The TSB doesn't require any check to determine if the seats heat to a specific temperature. The TSB instructs to technician to (1) perform a "network test" of the seat climate control module (SCME) and the front display interface module (FDIM) and (2) determine if there are any SCME diagnostic trouble codes. If the SCME and FDIM pass the network test and there are no trouble codes, the TSB says to replace the climate control seat and back pad units for both the driver and passenger. Before I bought the car, I asked dealer's service department if the TSB could be performed. The response was that there are no TSBs for the MKC. Really? Take a look at 15-0027. Oh. Hadn't seen this before, but can't do a TSB before you buy the car. They said they'd do it if I found the seats weren't heating effectively, but I have the impression that getting it done won't be without some degree of grief and hassle.
I have had these seats on our 2005 Aviator and a Navigator.
Some expert advice from an electrical engineer as well as research indicates that the solid state device used to cool/heat is not very efficient for cooling - the seat heating is good.
These Pelitier devices, or TEDs (Thermo-Electric Device) are the same ones used on those 12 volt portable coolers/warmers. Like the seats, these coolers do not produce ice cold cooling
On the other hand, these solid state devices are very durable compared to the usual heating elements inserted under the seat covering. Our Aviator is now 10 years old and the TED devices along with the blower motor still work fine, just don't expect a lot of cooling
The units on the Aviator and Navigator have air filters-make sure you keep these clean-they are durable and can be washed gently with some dish soap as the dealer wants a lot of money for these filters. Dirt can clog the small openings where the air flows through inside the TED device-this can be cleaned but needs to be done carefully.
I was disappointed that my MKC didn't come with factory seat cooling, so I added it. Under the front seats is an air vent to supply climate air to the rear passengers, I simply diverted the air flow up. While it's winter now, if I find this is not enough, I'll close off the open ends under the seat with sheet rubber to force more air into the seat cushions. This also does a nice job of heating the seats too. As an added bonus, air flow like this aids in drying the cushion materiel from rainy days or sweat. Also one will get some heat/cool to the back of the seat. If you want to test this before doing any modifications, simply put a bed pillow behind the seat to cover the hole.
1 - 12 of 12 Posts
