Mavrik:
Essentially NO except for a short distance at low speed with the ignition on and the vehicle in "Stay in Neutral Mode".
Otherwise, front wheel drive vehicles require a two-wheel tow dolly for the front wheels and all wheel drive vehicles require a trailer.
I suggest you download the owner's manual from the Lincoln site and read the section on towing.
· Administrator
I was looking into this the following was taken from the 2017 owners manual.
Front wheel drive vehicles CANNOT be flat-towed (all wheels on the ground) as vehicle or transmission damage may occur. You must place the front wheels on a two-wheel tow dolly. If you are using a tow dolly, follow the instructions specified by the equipment provider.
All-wheel drive vehicles CANNOT be flat-towed (all wheels on the ground), as vehicle or transmission damage may occur. It is recommended to tow your vehicle with all four (4) wheels off the ground such as when using a car-hauling trailer. Otherwise, you cannot recreational tow your vehicle.
