1 - 12 of 12 Posts
Greetings,
I am interested in giving this Forscan programming a whirl just for fun. I am interested in configuring two changes to my MKC. 1) Changing Sync 3 Theme and 2) Enabling rear-view mirror tilt down in reverse. I am running Sync 3, v. 3.0 Build 20204 on a 2019 MKC Reserve.
1) Theme - My car currently displays "Lincoln Timeless." I would like to change the theme to "Lincoln - D544 - blacklabel" which is one of the options in the testing options. Is this possible while not changing the splash screen and does anyone have the coding?
2) Mirror Tilt - I am interested in enabling side rear-view mirror tilt down when in reverse. I have seen this discussed elsewhere and was wondering if anyone has the exact coding for my particular build / version of Sync 3.
Thanks in advance for your help!
I know without a doubt how to change the splash screens when you are ready I can write up a step by step for you. I personally used to have the Black label splash screen.
As for mirror tilt, I don't know, I have read about people trying to get it on the f150 site. I will do a little more research and let you know if I figure it out.
Thanks! I am waiting for my OBD adaptor to arrive and then will be ready to give it a go. To be clear, I don't want to use the Black Label splash screen, just the theme. My understanding is that those are separate settings via Forscan. Thanks again!
Can you explain a little more what you mean? To me Black label theme refers to the different wood grains and leathers that come with the black label, for what I understand the radio is exactly the same other than the splash screen
Sure... For the head unit, there are options for the "splash screen" when the unit boots up; Lincoln, Ford, Mustang,etc. AND there are options for the color theme - Ford themes are blue, Lincoln themes are brown/goldish. Within the Lincoln sub-group of themes there are several options such as Lincoln Timeless, Lincoln Blacklabel, Lincoln D544, and Lincoln D544 Blacklabel. All are slightly different; font color, etc. Thanks
Just following up...
I was able to change the Sync 3, v. 3.0 color "theme" from Lincoln Timeless (gold w/ white icons) to Lincoln Next (gold w/ black icons) using Forscan (drop down, not "As Built"). Nice but subtle change. One of these days I might get brave enough to ry the CyanLabs 3.4 upgrade. Thanks
Nice job!! IMHO 3.4 is not worth the risk, I thought the Android auto maps in the IP would be great but the end the major benefit was the map update. Calm screen is just weird, and the colors from 3.0 are better than 3.4
I have done this upgrade multiple times to both ford and Lincoln and the ford colors are much better in 3.4 but they are too muted for Lincoln in 3.4. Once again IMO.
BTW can you show a picture of Lincoln next theme
Discussion Starter · #8 ·
Here is the "Lincoln Next" color theme in daytime mode. Notice the icons along the bottom are black, but the 'current screen' icon is beige. Also, certain fonts and symbols are beige as opposed to white. Additionally, the overall 'gold' color seems to be a bit darker. I prefer this look since my car has a black interior.
Gadget Wood Font Rectangle Technology
Gadget Font Audio equipment Personal computer Display device
Rectangle Font Technology Number Audio equipment
I agree, it's subtle but it really looks nice!
View attachment 6088 View attachment 6089 View attachment 6091
Do you have the spreadsheet of what you used to change this? I haven鈥檛 used forscan in a few years but just bought a 2018 mkc reserve with black interior
The APIM is the same across all ford lines so just look up F150 spreadsheet forscan and it will pull up the F150 information, sync2 is sync2 acrossed all lines in sync three is sync three across all lines
Discussion Starter · #12 ·
I'm sorry, I don't. That was my one and only foray into Forscan - but I remember it being very easy. No coding or numbers necessary - the theme options were spelled out with text "Lincoln Timeless," Lincoln Next" etc. Looks nice though!
Good luck!
1 - 12 of 12 Posts
