Bought new struts, I everything torn apart but I can’t seem to get the a-arm to come down low enough to get the strut out. Any suggestions?
Thanks for your suggestion. I will look into thisMan you never got any responses, sorry I don’t have a good response for you either. One option you could try is either loosening the bolt that is bushed to see if that will allow the lower control arm to go down a little bit or just removing the entire lower control arm. I’ve done a lot of struts but never done this one yet
