Does anyone know how to remove that button assembly? I've removed the top speaker grill and the two screws under that. From there I've removed side trim but something is still holding the center stack in and I cant seem to figure it out. I have purchased new gear selector assembly and want to replace it because the original is worn out. Any help with removal would be great. Thanks
2015 MKC
Remove the trim between the center stack and the center console and you will find it to 8 mm that face forward, you got to feel for them though and use a short socket and ratchet combo
Okay, so two on top Ander the speaker grill and two under the center stack. So just those 4 total?
Yes sir, the rest will will be wiring harnesses, I would call it behind the center stack instead of under, but yes.
