Thought it might be a good idea if we had a place for all the issues/quality complaints. I'm not saying there are or will be massive issues, but I think threads like this are valuable to potential shoppers...
That is strange, maybe they are just meant to be parking lights? So you're saying there's no separate fog lights switch and they aren't controlled at all in "auto"? I'm assuming it's the strip on the right side of this pic, and based on the location I would have thought they were fog lights.I did not know where to post this message, but anyhow, the two fog lights ( the two led bar located where the fog light usually are ) turn on only at parking light position on the light control switch. The fog lamps are off at the autolamps position on the light control switch. Is it possible to have the fog light on on the autolamps position ?
By the way.....after 1700 km, i'm still very satisfied with my car.
I also think that they are fog lights...........at autolamps position, only the light pipes underneath the headlamps are on.........I think that the fog light should be on.............is it the same situation for you guys? ( I mean that only the light pipes is on at autolamps position )That is strange, maybe they are just meant to be parking lights? So you're saying there's no separate fog lights switch and they aren't controlled at all in "auto"? I'm assuming it's the strip on the right side of this pic, and based on the location I would have thought they were fog lights.
I think you can control these lights mentioned in the vehicle setup (Lighting?), controlled by the left "buttons" on the steering wheel. They may be considered Daytime Running Lights, as I know the MKC does not have "fog" lights per se.I also think that they are fog lights...........at autolamps position, only the light pipes underneath the headlamps are on.........I think that the fog light should be on.............is it the same situation for you guys? ( I mean that only the light pipes is on at autolamps position )
I just realized that I do not have that ''daytime light'' feature inI think you can control these lights mentioned in the vehicle setup (Lighting?), controlled by the left "buttons" on the steering wheel. They may be considered Daytime Running Lights, as I know the MKC does not have "fog" lights per se.
1 ) After having experimented it on my MKC, I do confirm that the fogI believe they come on when car is in "drive".
JasDmw, have you seen some official notice or are you referring to the Edmunds report? 2015 Lincoln MKC Recalled for Bubbles in Windshield | Edmunds.com Thx.Here it is officially;
Ford said it is recalling 1,274 Lincoln MKC SUVs from model year 2015 because there may be bubbles or other defects in the windshields. Air may have become trapped between the layers of glass during the windshield supplier's manufacturing process, which could lead to bubbles developing that could affect driver visibility, Ford said.
Ford said it is not aware of any accidents or injuries related to the issue. It will replace the windshield at no cost.
Affected are about 1,139 SUVs sold in the United States, 117 in Canada and 18 in Mexico
Oil pressure and temp gauges are pretty rare if even existent at all in cars aside from most pickup trucks or actual truck based SUV's (which are also nearly dead). I've had two turbo cars a 2001 VW Passat and currently have a 2012 Audi A4 and neither have those either. I honestly can't say any of my cars have ever had a light under the hood either, though I can see how that could be useful. Again I feel that may be more a truck like feature.The MKC has 500+ miles on it and I have NO quality issues at this time. I do however have issues with the car. A $44.000.00 car with a turbo and it doesn't come with a oil pressure or oil temp gauge. That is just plain wrong with a turbo engine.. Also there is no under the hood light! Not a big fan of holding a lite with teeth. My cheapo Chevy truck has one and a oil pressure gauge, TOO ! Then there is the lack of tire monitors for each tire. ****, my neighbor's cheap disgusting KIA has one. It's easy to see the bean counters are still in charge here.
