Hello all..I have an issue that my dealer has given up on that is unacceptable to me. They are going to refer to an engineer, but in the interim could use some guidance.
The issue that I have is a noise that has developed in the last 6 weeks. It sounds like a flutter (metallic) or something that is vibrating/touching not turbo related.It appears to be on the driver side. Here is how to replicate the sound 100% for me.
Only happens when the car is on
Happens when the car is warmed up at normal RPM's
Happens when you put your foot on the accelerator with extremely light pressure (stop and go traffic)
Only happens when a load is put on the engine to the point that the car can creep and reproduce the noise
Does NOT happen when the car is stopped must be in gear and moving
When it first started it would go away after a few minutes and not happen again until it restarted; now it is ALL the time
Tech that worked on the car said he cannot hear it from the outside; my daughter said she could hear it from the outside (tech is older and states his hearing may not be what it used to be)
My servicing dealer has given up. Tech Line told them it was the fuel pump but has checked out as okay and not the source, the tech tried removing the windshield cowl and tried moving cables/wires/hoses to no avail.
As far as I know there has been no higher tech involved other than the technician
It is extremely frustrating and a deal breaker for me, I can not drive a car that makes this noise
An engineer may take 2 weeks before he gets to me
Any clues?
Thank in advance
Any clues?
Thank in advance
