If you shift in neutral and open the driver's door, it will automatically shift into park unless you hit Neutral twice. As per the manual
AUTOMATIC RETURN TO PARK
Note: This feature will not operate when your vehicle is in Stay in Neutral mode or neutral tow.
Your vehicle has a safety feature that will automatically shift your vehicle into park (P) when any of the following conditions occur:
You turn the ignition off
You open the driver's door with your safety belt unlatched
Your safety belt is unlatched while the driver's door is open
If you turn the ignition off while your vehicle is moving, your vehicle will first shift into neutral (N) until it slows down enough to shift into park (P) automatically.
Note: If you have waited an extended period of time, (2-15 minutes) before starting your vehicle, unlatching your safety belt will cause this feature to activate, even with the driver's door closed.
Note: This feature may not work properly if the door ajar switch is malfunctioning. If your door ajar indicator does not illuminate when you open the driver’s door or the indicator illuminates with the driver’s door closed, see your authorized dealer.
To engage Stay in Neutral, do the following:
STAY IN NEUTRAL MODE
Stay in Neutral mode allows your vehicle to stay in neutral (N) when you exit the vehicle. Your vehicle must be stationary to enter this mode.
To enter Stay in Neutral mode:
Press the neutral (N) button on your shifter assembly.
A message will appear in your information display.
Press the neutral (N) button again to enter Stay in Neutral mode.
A message will appear in your information display screen when your vehicle has entered Stay in Neutral mode.
Note: During this mode the N button will flash continuously and your instrument cluster will display N as the selected gear.
EXITING STAY IN NEUTRAL MODE
To disable Stay in Neutral mode select another gear. See the Putting the Vehicle in Gear for instructions on how to do this.
ENTERING A CARWASH
Note: Always put your vehicle in Stay in Neutral mode when entering an automatic car wash. Failure to do this could result in vehicle damage not covered by warranty.
