1 - 1 of 1 Posts
New SSM 47204 Rough engine idle
Engine Runs Rough With Diagnostic Trouble Codes (DTCs) P0300, P0301, P0302, P0303, P0304 And/Or P0316 – 2015-2018 Ford & Lincoln
SSM 47204 – 2015-2018 Various Vehicles – 2.0L EcoBoostEngine Runs Rough With Diagnostic Trouble Codes (DTCs) P0300, P0301, P0302, P0303, P0304 And/Or P0316
Some 2015-2018 Fusion/MKZ/MKC/Escape/Edge vehicles equipped with a 2.0L EcoBoost engine may exhibit a runs rough condition with DTCs P0300, P0301, P0302, P0303, P0304 and/or P0316.
This may be due to coolant intrusion due to corrosion on the engine block.
To diagnose this concern, with the engine at normal operating temperature, pressurize the cooling system to 138 kPa (20 psi) and hold for 5 hours.
If the coolant pressure drops 27.57 kPa (4psi), remove the spark plugs and inspect for coolant in the cylinders.
If coolant is found in any of the cylinders, replace the engine long blockassembly.
Follow normal prior approval process for your Dealership.
However, follow the diagnostic repair procedure in this article to determine correct repair.
For claiming, use causal part 6006 and applicable labor operations in Section 6 of the SLTS Manual.
APPLICABLE VEHICLES
2015 – 2018 CAR: ED CD539(APA)-EDGE
2015 – 2018 CAR: DQ CD539N-EDGE
2015 – 2016 TRUCK: M2 C520 NA (ESCAPE)
2017 – 2018 TRUCK: M2 C520 NA (ESCAPE)
2015 – 2018 CAR: C7 FUSION
2015 – 2018 TRUCK: ME C489 LINCOLN CUV
2015 – 2016 TRUCK: ME C489 LINCOLN CUV
2017 – 2018 TRUCK: ME C489 LINCOLN CUV
2015 – 2018 CAR: C9 MKZ (CD533)
1 - 1 of 1 Posts
