1 - 2 of 2 Posts
I have to replace the front passengers door due to a accident. Is the wiring connection below the carpet right by the door? I don't want to take the door off and have it hanging from wiring. The door is so mangled I cant pull on the wiring to see which harness it is.
Sanman
Discussion Starter #2
For everybody that see this post later:
To remove the doors you do not need to take anything off in the interior of the car. The connection is directly behind the plug in the pillar. Gently and carefully pull the plug out the pillar. Then unplug the wires. I disconnected my battery before removing the doors.
1 - 2 of 2 Posts
