Curious about others experience with power active mode (Lincoln fancy name for running electronics/audio without running the engine)
I sometimes listen to my stereo in my garage while cleaning without starting the engine. I also like to listen to music tail gating for shows/sports. Previous cars I've done this for up to an hour without draining the battery.
The MKC (thankfully for me maybe not others) has an automatic shut off mode of power active after a certain times (it appears to be 15 or 20 minutes) which shuts off the power in case you walk away and forget. If I use it more than 15 minutes I just reach in window and hit start button to re activate it and continue to listen. I thought I had been doing this a few times without issue.
The last few times I did the power active ran through the first 15 minute "cycle" then shut off. When I reached in to turn it on again everything was black and a message came up saying "turning off power active mode to save battery". I then could not run anything until I ran the engine (something I obviously don't want to do if I'm in a garage or in tight parking running my engine in someone's face sitting hanging at their car).
Wondering if anyone else uses this feature and what your experiences have been with it. Dealer mentioned a "setting" maybe but to me it sounds like what it's saying, that running power active mode is draining the battery to an extent that the MKC feels it needs to shut it down so the battery doesn't go dead. Think it's a little odd that you risk battery draining completely with running power active 20 minutes but then there is a lot of tech and electronics in the vehicle.
Thoughts?
Thoughts?
