I came here in hopes to get help with an issue involving the auto climate setting in my 2017 MKC Select. A new issue has crept up whereby my auto climate system doesn't seem to be adjusting the fan speed until it is cranked to the highest temperature. It seems to only be a problem on the heat setting as turning it to the coldest setting does seem to change fan speed. It's hard to tell if this is a new issue as we only recently starting getting cold winter temperatures around here. The fan virtually doesn't blow unless the heat is at max. Switching out of auto allows the fan to work normally. Does anyone have any idea if this is perhaps a bad sensor or something else?
Any input would be appreciated!
