21 - 27 of 27 Posts
My 2017 MKC has now been in the shop six times with a dead battery. Lincoln seems to have no clue how to fix it or that they even have a systemic problem. They have replaced the instrument cluster, the battery, module replacements, applied various updates and most recently the gateway module. Each time they assure me the problem has been fixed. This trip (two months since my last visit) the vehicle has been in the shop 10 days - awaiting the "rush delivery" of the part - I repeat 10 days for the rushed the delivery of the module. I am told the part will arrive today, a day or two to install, they'll keep it for a day or two to test. They will send me home with it saying it is fixed, not really knowing and I expect to be back in 2-4 months with a dead battery, unless it dies right in the shop as it did earlier this week
What also bothers me is they seem to be unable to piece the various other items I tell them, which I believe are all related, but they just hook it up to a computer and do what it says - interestingly it comes up with a different reason each time. The Lincoln app works off and on (it does months without talking to their server, but I think it continues to try), the welcome lighting no longer works, the car does not automatically unlock when you grab the handle - but they ignore all these other issues.
It is getting close to lawyer time.
I would not wait any longer, contact an attorney now...It is best to be proactive, and based on what you've written there is little expectation to have it working correctly. Create a case with Ford/Lincoln to show that you have tried, in good faith to resolve this. If you can show at least 4 attempts or out of service for more than 30 days, you will have a better chance at success. I'd also recommend contacting the BBB.
Same problem with my 2017 MKC. Have had it in the shop 4 times. Changed battery, changed ACM, did rear lift gate thing. Battery won't even hold a charge this time. Have to keep a booster pack in the back. Out of ideas and patience. Considering the number of folks with this problem, Lincoln is failing big time. Anyone find a solution?
Any update on this issue?
The sound when closing the gate is different just like the others comments are saying. Can only stay on accessories for 2-3 mins max before the shutdown occur. I have a MKC 2017.
Thanks to all.
Having same issue...
Thanks to all.
Does anyone have a solution to this yet? Still having same problems with the dead battery.
Have you taken it to the dealer for any recalls, some of these models have recalls on the software because this is a known issue with a few of the modules, second I would have them just do a complete update on all your modules, of course replace with a known good battery that’ll be your cheapest option, if that doesn’t fix it unfortunately the diagnosis starts to get expensive. And require special equipment that I don’t even have, and I’ve got a pretty good amount of specialized equipment
21 - 27 of 27 Posts
