1 - 11 of 11 Posts
I made the changes to show tire pressure but get nothing.
I have the latest FORSCAN, there's 3 TPMS settings: TPMS menu (additional change required in BMI) the PSI you want to use, TPMS placard pressure display and TPMS by location units PSI, kPa or bar.
I enabled TPMS menu @ 35PSI and placard display and set location to PSI. Wrote it all, turned car off on and nothing.
Ideas?
TIA
I have not done it lately, I’ll download the latest software and take a look at what you’re doing.
Rectangle Azure Font Line Screenshot
Here is the settings I am using. Try these and let me know if that works. If so I will update the original walkthrough
@bullitt try version 2.3.34. I know the version works
so there is an option in that version called tire pressure gauge. Did you enable that? It will not show up with a tpms search
ok I don't know what else to do to help, sorry. I don't show tire pressure gauge either in the new versions of forscan but it is there when i use version 2.3.34.
1 - 11 of 11 Posts
