I just got a parking spot in my apartment complex’s garage. The ceiling height in the garage is extremely low. If I open the trunk will the trunk automatically sense the low height and stop before it hits the garage ceiling, or is there at least setting for different opening heights? (I’ve seen this setting in other vehicles)
I cut and pasted this out of my manual...
Setting the Liftgate Open Height
1. Open the liftgate.
2. Manually move the liftgate to the desired
height.
3. Press and hold the button on the liftgate
until you hear a tone, indicating
programming is complete.
Note: You cannot program the height if the
liftgate position is too low.
The new open liftgate height will now be
recalled when the power liftgate is opened.
To change the programmed height, repeat
the above procedure. Once you open the
power liftgate, you can manually move it to
a different height.
If the programmed height is less than
full-open, you can fully open the liftgate by
pushing it up. The programmed height
remains set until you change it.
There is an illustration that won't copy, that shows where the button is. If you have a manual, it is under the section: LOCKS, Subsection POWER LIFTGATE
