As far as I am aware,yes. Obviously Ford derived.Just checked and my 2015 has A5.
Will any A7 work in the MKC?
Really no messing. It's an SD card that's easy to swap out.I asked my dealer about that. He asked are you having any issues, I said no, he said I wouldn't mess with it. I agreed with him.
I am guessing there must be some sort of encoding in the "real" SD card that keeps most folks from just copying the files to another SD card. I got an A7 SD card off E-Bay for around $50. Watch the prices there and you should be able to get one in the $50-$60 range. Better than the $150 the Navi people want.Hi all. new user here. Trying to do teh updates manually. Got hold of all A7 files from a guy and put on a SD card. Sync says something like invalid card. Ford parts guy (not same guy as source) said if i bouhgt a card from them it would be simpel plug and play , more like shrug and pray. Anyone tried this way with any sucess?
If you have a newer A7 card, why would you flip back and forth?I am guessing there must be some sort of encoding in the "real" SD card that keeps most folks from just copying the files to another SD card. I got an A7 SD card off E-Bay for around $50. Watch the prices there and you should be able to get one in the $50-$60 range. Better than the $150 the Navi people want.
It is a simple plug and play. I have one Lincoln with the A7 SD card and an older one with the A5 SD card. If I am going on a trip where I don't know the road, I just swap the new one into the car I am going to drive on that trip, so I have newer data. I have flip-flopped them back and forth 5 or 6 times in the last 6 months since I got the A7 SD card. Never a problem.
Sorry, probably wasn't clear. I have two different Lincoln Cars (MKC and MKZ), one with an A7 and one with an A5. When going into unknown areas (or long trips) where I know I will be using the nav alot, I usually put the A7 in whatever car I am driving that day.If you have a newer A7 card, why would you flip back and forth?
