1 - 1 of 1 Posts
Has anybody had that warning above come up on the GPS screen, followed immediately by 7 other warning lights on the instrument cluster (power train fault, stability control, steering assist default, service advance trac, parking brake malfunction, check rear park aid, see manual), and the turn signals don't work. Car only has 251 miles. This is the second time this has happened. The first time this happened (about 170 mi) I was able to limp home, turn signals worked, cleared the warnings on the instrument cluster, and everything appeared to be fine the next morning. About the only thing that works now is the radio.:frown
I will call tomorrow to see if Lincoln can tow the car to their shop. My thought is that it may be a loose wire somewhere, cold solder joint, or a bad sensor (front airbag?)
1 - 1 of 1 Posts
