So the Meguiar's Next Tech does not change the appearance of the exterior plastic/interior vinyl? We've been wondering what to apply because we do not want any of the surfaces to appear "shiny". Would the NXT do the trick?Suggestion, first as you know you never want to get WAX on plastic/rubber it stains it and sometimes you can not get the white stain removed.
That said buy Wax & Grease remover for best attempt it is sold where auto body paint supplies are sold as it is used to remove Wax before painting/prepping.
Also I highly recommend switching over to a sealant. It lasts longer than wax and many do not stain plastics/rubber. I personally use Meguiars Next Tech (NXT) and love it. I go so far as to purposely put it on all exterior surfaces... Glass, Plastic, Rubber, Vinyl all are not effected but are protected.
I know that paint sealers such as opti coat will protect the original look of the color to some extent, specifically with UV protection as one of them i'm aware of.Suggestion, first as you know you never want to get WAX on plastic/rubber it stains it and sometimes you can not get the white stain removed.
