For anyone with a 2015 MKC, can you check your IPC settings and see if Welcome Lights is an option? I recently lost my welcome lights and it is currently at the dealer being looked at, mine did not have the ability to turn them on or off. Thanks!
MSM:
According to the 2015 owners manual you should have the following settings available:
VehicleDrive ControlHandling in D Comfort, Normal or SportDTE Calculation Normal or Towing
Handling in S Normal or Sport
Performance in S Normal or Sport
Easy Entry / Exit - check enabled or uncheck disabled
Auto Engine Off - check enabled or uncheck disabled
LightingAuto Highbeam On or Off
Autolamp Delay Select time interval
Daytime Lights On or Off
Welcome Lighting - check enabled or uncheck disabled
