thanks so much, i didnt knew that, i will call them upHey Moe either synthetic blend or full Also you get oil changes free for the first 2 years . Call your dealer to set up the maintenance .
i usually make a oil change every 8-10K miles, i think i will go to a local mechanic VS dealer since i have to travel and they will always find some problems which means $$Not that it matters for a few years, but the OEM recommend oil is the same as I use in the Stangs. Motorcraft 5-30 semi synthetic. Wish they sold it around here in the 5 quart container. As I'm not a fan of fast oil changes!
Even finding an independent shops that specializes in Fords will serve you well, usually they're no-B.S., just get the job done.i usually make a oil change every 8-10K miles, i think i will go to a local mechanic VS dealer since i have to travel and they will always find some problems which means $$
