1 - 20 of 25 Posts
I ordered my MKC AWD 2.3 with the standard 18" wheels, but am having second thoughts -- those 19" wheels look awesome in comparison. However, I'm concerned that the 19" wheels will give a rougher ride, be noisier, and perhaps lower gas mileage a bit. Any thoughts/advice out there on this?
I had the same thinking as you. But after a few research, I went 19" for a few reason.
First of all, the 18" tire is 50 in height. The 19" is 45. So, there's really not that much difference if you compared it with a 60, which is not an option.
Then, the 5 spoke 19" wheel just looks much better. The 20" looks plain ghetto IMO :(, and will definitely be harsher @ 40 in tire height.
I planned to go with the 19's had I proceeded with my order, primarily because I prefer the looks. In theory, the 18's should give you a more comfortable ride, but given the MKC's comfort-oriented suspension I'll be surprised if most people can even feel the difference. There is 1/2" less sidewall to protect the wheels when you step up to the 19" option, so that would be a bigger concern for me, and the main reason I wouldn't personally consider the 20's. (You may have heard ... we have a few potholes here in Michigan.) You might want to look at what tires are available in each size before you make a final decision. 19's aren't as common as 18's or 20's, so you may find better tire options if you stay away from the 19" option.
18's are the best value. 19's and 20's are both quite expensive especially for the rubber band esque tires they wear!
Ordered the 19" wheels & drive "pothole country"! In looking at extended warranties, I see there's now a wheel & tire add-on listed. Most coverage of the tires looks like a duplication, but after reading some of your comments above, I'm wondering if more likely to damage these wheels than the 17" wheels on the Zephyr. Thanks for any words of wisdom.
do you know what the aspect or sidewall ratio is on your 17" zephyr wheels? Would be easier to compare that way
Reading the Tire's Sidewall - Discount Tire
I want to buy the Premiere & the wheels look bad.
How can i get other wheels for the Premere because i can't see spending $3000.00 more just to get different wheels.
Any sugestions welcome.
Have you looked at the build your own feature in the Lincoln-MKC website?
Looks like there are 3 other wheel options for a 2.0 FWD Premier, plus the standard wheels.
2015 Lincoln MKC Base: Build and Price | Lincoln
Hopefully others jump in with an opinion. I think the MKC need a little more "wheel bling" certainly compared to the base, standard wheels. The second/lower version adds that, and still looks classy, more expensive, more interesting...but maybe more work to keep clean?
1 - 20 of 25 Posts
