1 - 7 of 7 Posts
Saw an mkx with a great set of polished chrome wheels that appear to be factory. Are mkx wheel widths and offset the same as mkc?
Jim
Yes and no, a direct fit, no, but it can be made to fit if you really want to.
This site is very helpful if you want to know if it is a direct fit or not.
https://www.wheel-size.com/size/lincoln/mkx
Different OD tire but same bolt pattern and same offset so, yes they will fit.
You may want to double check, the lug sizes are different. MKX M14 x 1.5 MKC M12 x 1.5
Yes the rim will fit but the lug holes will be slightly larger. I would recommend also replacing the lug bolts on the MKC if one goes with a MKX rim.
BTW I had like new snows from my Evoque, and wheels had same pattern, so I used them. Size is 235/60R18. Yes they are larger by 1 inch. Car has a more SUV like look now. Ride is phenomenal. No negatives unless you think big dubs look better. On the lousy roads I run in winter, this is ideal. BTW Ford did a lousy job with stock tire sizing on this vehicle because there is already a ~.75 inch difference from the 235/50R18's to the 255/40R20's. Speedo is spot on with the 20's but ~1.5mph fast with the 18's. Speedo runs 2 mph slow with the 29.1 OD 235/60R18's. They do fit and will probably be my go to size in the future. Moda MD18's look sweet on the car.
Jim
Jim
Suggest you go to a site like Tire-Rack, and see what they have. They have plenty of options and the exact fit for your MKC.
Reactions: ddsski
1 - 7 of 7 Posts
