Not under warranty. The car has rain sensors which automatically activates the wipers when it detects moisture. That’s not working nor is the fluid dispensing. Only the highest speed works when engaged by the stalk. The rear wiper is also not workingis it still under warranty? (so you can just take it in)
What happens when you press the fluid button? goes slow? no movement? only fluid coming out?
do you hear a motor whine when the switch is on slower speeds?
play with the stalk to see if it works or initiates the blades. (wiggle near where it goes into steering column, push in or out)
Hi Sandy - my 2017 mkc just started doing the exact same thing . Was it ever diagnosed for you ?Have a 2017 MKC. Front windshield wiper only works on high and sensor doesn’t work. Rear wiper not working at all. Anyone know what the problem could be? Appreciate any help
