As moretti said, another forum member had some issues with their hood flexing, but if I recall correctly they noticed it when driving over bumps or uneven places in the road.the hood latch is locked tighted and the hood sometimes flutters going 70mph on a windy highway. did anyone else observe this?
If you start having with your hood shaking the first thing you need to check is the wind / debris cover under the vehicle. The broken cover allows air into the engine compartment causing the hood to lift and shake violently.I have a 2015 MKC and I have not noticed any shaking of the hood at all at highway speeds.
If you start having problems with your hood shaking the first thing you need to check is the wind / debris cover under the vehicle. The broken cover allows air into the engine compartment causing the hood to lift and shake violently.I have a 2015 MKC and I have not noticed any shaking of the hood at all at highway speeds.
countryguy- Thats a good possibility but where is this wind/ debris cover located?If you start having problems with your hood shaking the first thing you need to check is the wind / debris cover under the vehicle. The broken cover allows air into the engine compartment causing the hood to lift and shake violently.
